Reverse Clip (donut) With Raster Data
4630
11-15-2021 03:29 PM
ParkGIS307
Hello all,
I have a DEM file I am working with. I want to take a polygon of a water body and remove those elevations from the elevation dataset.  What I want to do would be similar to the erase tool but instead of vector data I am working with raster. The DEM file would look something similar to a donut after this. So far I have come up empty-handed as I try to figure this out.
Does anyone know how to do this or know of a work-around?
2 Solutions
DanPatterson
MVP Esteemed Contributor
convert the polygon to a raster using the same extent, cell size and alignment etc.
You can use the Con tool in arctoolbox to remove the elevations in the water body
Con (Spatial Analyst)—ArcGIS Pro | Documentation
Con("Lake", "Elev", 0)  # if you want to set the value to 0
or
Setting values to NoData with Set Null—ArcGIS Pro | Documentation
SetNull("Lake", "Elev")
... sort of retired...
JayantaPoddar
Please ensure you are using Clip function (not Clip Geoprocessing tool).
Think Location
DanPatterson
or
JayantaPoddar
You could use Clip function—ArcGIS Pro | Documentation
Clip Type: Inside
Think Location
ParkGIS307
Where are you using the clip type options for inside or outside? This is the raster clip function but I do not see that option for outside/inside.
JayantaPoddar
Think Location
ParkGIS307
That worked great. Thank you.
