Remove From Project grayed out on Pro project
2431
09-04-2024 02:31 PM
RandyKreuziger1
I created a Pro project in 3.2 on a network drive.  There is a toolbox and a folder in it that I don't want others to see but I can't remove them.  Both show "Remove From Project" as being grayed out.  Seems so basic but it remains grayed out even after restoring Pro and rebooting.  I had originally added two toolboxes to the project but it let me remove one of them.
Also, the project is one I created and in a network folder that I have all permissions to.
DanPatterson
MVP Esteemed Contributor
before you create the project, go to the project backstage and change these settings so that a default folder and toolbox aren't created
... sort of retired...
WDFWAdministrator
There is no default toolbox.  The toolbox is one of two I added to the Project.  I was able to remove one of them but not the other.
DanPatterson
strange, the only time I remember havin had an issue like that was when I didn't clear geoprocessing history (which may refer to a tool in a custom toolbox) but that was many versions ago and when I used to store geoprocessing history
RichardHowe
Pick any other folder and set that as the default, then you will b able to remove the "L:\" one. In your screenshot the folder you are attempting to remove is already the default (indicated by the little home icon next to it) and so it won't let you. Same goes for geodatabases and toolboxes
