Reading Geodatabase - This container is empty
3300
6
11-21-2021 01:11 PM
PeterGreen
New Contributor II
I created a file geodatabase in ArcMap 10.8. I then created several raster mosaics and imported a Sentinel-2 image and various elevation layers. Everything worked fine. I then imported the ArcMap project with the raster layers into ArcGIS Pro 2.5. The project imported successfully including the layers, however when I try to access the geodatabase it appears empty. In both Catalog view and pane there's a message that says "This container is empty". Can anyone advise what I'm doing wrong here.
Thank you.
JayantaPoddar
MVP Esteemed Contributor
Do you have ArcMap 10.8 in the same machine?
If yes, could you check if you are able to access the GDB and view its content?
If you can access the content of the GDB, then
1. Using ArcGIS Pro, create a new file Geodatabase.
2. Using ArcMap, execute Raster To Geodatabase to copy the raster files in the new geodatabase. Check if you are able to view the content of new geodatabase from ArcGIS Pro.
Let me know if there are any concerns.
Think Location
JayantaPoddar
I would suggest upgrading ArcGIS Pro to the latest version (if possible), and try again.
Think Location
PeterGreen
New Contributor II
Thank you @JayantaPoddar. I was just in the process of doing that. I'm now running v 2.9 but I"m still receiving the same message. Regards.
JayantaPoddar
Think Location
PeterGreen
New Contributor II
Thank you for your responses, Jayanta. Apologies for the slow reply. Your suggestion worked perfectly. Kind regards.
JayantaPoddar
Great!
Could you mark that response "Accept as Solution", which resolved your issue? This would help others facing similar challenge.
Think Location
PeterGreen
New Contributor II
Yes, all done. Thanks again!
