Re-locate points based on their xy added field
545
01-13-2024 10:19 PM
Labels (3)
NisreenAlhindi
Dear All,
I have multiple points in a layer that I want to relocate based on new x y that I already added from different resources" but with the same coordinate system".
The x y field was added to the new layer but is there any tool that I can use to re-locate the points based on the newly added xy fields?
DanPatterson
MVP Esteemed Contributor
Have a look at Xander's solution
Solved: Updating Shape Field from Lat/Long Fields - Esri Community
... sort of retired...
NisreenAlhindi
Thank you so much I checked also the following ESRI community post
https://community.esri.com/t5/python-questions/move-point-features-based-on-xy-values/td-p/715045 the 2 methods work for me!
Thank you!
