"Add to project" on a file geo database does nothing
733
05-24-2024 09:39 AM
Labels (2)
DonaldPike
I'm trying to follow some instructions for adding an exported & downloaded feature layer from arcgis online to a project in arcgis desktop pro. I've downloaded a feature layer in FGDB format and extracted it. However when I navigate to the FGDB object, right click on it and select "add to project" nothing happens.
Here's a screencast:
https://d.pr/v/c6IMrE
Is this expected behavior? Shouldn't there be a success or fail message? If this is an invalid operation, then the menu option should be grayed out.
Tags (1)
Robert_LeClair
Esri Esteemed Contributor
So you're almost there!  In the Catalog Pane, click the Project tab at the top, then click Databases and expand the databases folder.  You'll see your fGDB there!
Robert_LeClair
