PYTHON
1613
5
03-19-2020 09:37 PM
KalSsin
Hi~~~~
if arg.endswith("산"):
return 3
Help me please....
DavidPike
MVP Notable Contributor
do you have multiple instances of the table open? close down all your ArcGIS applications and open up a fresh mxd then retry.
DanPatterson_Retired
return 3  is a number and will produce an error
return "3"  or  return str(3)  .... will return a string representation of a number which you can use in that field
DavidPike
Hi, try adding an else statement to handle the bulk of the values which don't meet the condition.
def Reclass(arg):
    if arcg.endswith(""):
        return "3"
    else:
        return arg
KalSsin
Thank you for your reply.
DavidPike
KalSsin
There must be an invisible error in the layer.
It's solved by using a different layer.
Thanks for your help.
