Preserving Global IDs with ArcPro 3.2 Append
680
14
01-10-2024 09:40 AM
ZachBodenner
MVP Regular Contributor
I've been having some trouble using the updated append tool since upgrading to ArcPro 3.2. So I have  a feature class (A) that I am migrating to a new feature class (B).  A has global IDs enabled, which are required for photo attachments and a related table, and so B feature class must have them enabled as well. I set up Feature Class B and enabled Global IDs.
Okay, so now when I go to append features from A and use the field mapper, GlobalID is one of the mappable field. If I run the append by filling out the GlobalID field, the correct Global ID does not get written in to dataset B - it's just a new GlobalID
I discovered this after my initial workflow failed: I went into the environment settings and selected Preserve GlobalIDs and then left the field map option blank. But that results in the Global ID of feature class B being written as 000-...
Which, if I'm appending more than one feature, will fail on the second feature because it's trying to write the same value to all the records.
What am I missing? Prior to 3.2 I was able to do work like this with no issues at all.
Tags (3)
ZachBodenner
Absolutely! I will illustrate with pictures:
Attempt 1: I use the field mapper to make sure that the GlobalID from my input dataset is being written into the GlobalID of my Target Dataset. I leave the environment setting "Preserve Global IDs" unchecked:
 When I do that, you can see that the GlobalID is not actually written in correctly:
Attempt 2: As above, except this time in addition to matching GlobalID from the Input to GlobalID from the Target, I also make sure the environment setting is checked on too:
 The result is now what we're looking for, the Global IDs are written in correctly.
DanPatterson
not sure if this is related
BUG-000156786 for ArcGIS Pro (esri.com)
... sort of retired...
ZachBodenner
Possible, though after doing more testing the solution is that both options need to be enabled - that is, in the field mapper you need to set Global ID from B to equal Global ID from A and also the environment setting needs to be set to preserve Global IDs. Seems counterintuitive that it should be the case, but I'm back off and running so I'll take it!
StefanBrandt
Pardon me, but could you elaborate on your solution? I have run into the same issue as you described in your original post, but have been unable to solve it.
ZachBodenner
DanPatterson
Tool environment settings should take precedence over any other setting set elsewhere.
I couldn't find a global setting for preserving global ids in the project, options, settings under geoprocessing or editing or elsewhere
ZachBodenner
Yes it definitely should, though as I mentioned in the original post, when I had the field map Global-to-Global not set, but the tool environment Preserve Global IDs toggled on, I was getting a tool failure.
DanPatterson
it now says In Product Plan dated Feb 12, 2024, so I presume for 3.3
LMedeirosUI
@DanPatterson Does this link still work for you? I am getting a 404 page...
DanPatterson
It appears to be gone now
