Polygon to raster conversion - how to sum values of overlapping polygons
4284
12-11-2023 02:39 AM
LizanneRoxburgh
I have a shapefile with a few hundred overlapping polygons (these are minimum bounding polygons that were fitted around species distribution points). Each polygon has a value. I need to end up with a raster in which each raster cell has a value that is the summed value of the polygons that overlap with that cell. Can anyone advise on the workflow I could use in ArcGIS pro to achieve this?  Polygon to Raster does not seem to allow summing the values of the overlapping polygons.
Remi_Foicik
Hello Lizianne,
I don't know if I understood correctly but you can try the following workflow.
Create a Polygon Feature class like a Grid (each polygon would be a cell in your raster).
Use "the summarize within" tool where you can apply  SUM on the fields in you shapefile.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/summarize-within.htm
Then you can translate you feature class "grid" to a raster with "the  feature to raster" tool.
It may not be the most beautiful solution, but it can work 🙂
Another solution :  you can transform each polygon into a raster and then apply a raster calculation with all your raster.
Rémi
Remi_Foicik
Hello Lizianne,
Rémi
LizanneRoxburgh
Thanks Remi, that worked perfectly, as we had already set up a grid polygon for processing other layers, so this was the quickest solution.
DanPatterson
MVP Esteemed Contributor
An elegant solution which works is provided here
Counting and rasterizing polygon overlaps in ArcGIS Desktop? - Geographic Information Systems Stack ...
which entails union, dissolve and convert to raster
That will give you the counts within each overlapping area.
otherwise,
Split by attribute   to get individual layers from the polygon input
Convert to raster
reclass nodata to 0
add the rasters together (Plus tool or just + )
paying attention to cell size, alignment and snap raster
... sort of retired...
