Polygon fill color is wrong.
2127
08-16-2024 11:47 AM
MarkLaPlante
I hope I have this posted in the correct place. I searched and could not find an answer. The bottom polygon should have a red fill as indicated in the dropdown. The outline should also be red. There are a number of polygons that have the incorrect color is there a way to fix this? I am not seeing the issue on other projects.
BarryNorthey
It appears that you are running the following that may be causing the problem:
Eugene_Adkins
In the table of contents choose the layer in question, right-click, choose symbology. From there, it's very straight forward.
Symbolize feature layers—ArcGIS Pro | Documentation
Hope that helps.
MarkLaPlante
Thank you for your kind response. The issue is not finding how to change the color. The problem is that the colors don't match what I select. It is only on this particular project.
Eugene_Adkins
Ok. Kinda sounds like a transparency issue then. Check and see if transparency is turned on for that particular feature.
*Either that, or maybe you simply have an additional layer on top of it?
BarryNorthey
MarkLaPlante
Thank you, Barry! Ironic that I didn't see that.😆
