Points inside or near polygons
1967
06-13-2023 11:01 AM
CarlosCogollo
I have polygons and points in ArcGIS Pro, most of the points are located close to the limits between polygons, these points that are inside a polygon but very close to the other polygon influence not only the polygon where they are located but also the nearby neighboring polygons How can I count how many points affect each polygon in ArcGIS Pro, that is, the points that are inside the polygon and those close to its border in a distance of 20 meters and how can I list these points that affect each polygon, that is, those that are inside and near the polygon at the desired distance.
One more question, if there is a polygon inside another larger polygon, does this cause a problem when counting the points?
I'm working in ArcGis Pro 3.0.3
JohannesLindner
Summarize Nearby does what you want, but it creates a new feature class.
If you want to add a field to the polygon fc, you can do so with Calculate Field. Switch to Arcade and use this expression (change line 1 to your point fc name):
var point_fc = FeaturesetByName($datastore, "PointFC")
return Count(Intersects(point_fc, Buffer($feature, 20, "meters")))
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
CarlosCogollo1
Thanks!
