Performing a spatial join based on a tabular criteria
2286
08-01-2022 02:29 PM
AdrianWelsh
MVP Honored Contributor
Hi, I am assuming this cannot be done in one step but I am curious to know what the Community thinks!
I am doing a spatial join between two similar layers but I only want these layers to spatially join if a certain attribute matches that same attribute between the two layers (so a table join within a spatial join). Is that possible?
I have not seen a way in which this can be done in one step. I would just do a "select by attributes" after the fact and find where those two fields match up and then make a new layer based on that. I am trying to eliminate multiple steps. I'm using ArcGIS Pro 3.0.
DanLee
by Esri Regular Contributor
DanLee
AdrianWelsh
Thanks Dan. I was looking in the search but didn't see that! I am glad that it is under consideration! Looks like Align Features is close but it does not do point layers.
DanLee
You are welcome!
Since you mentioned Align Features, are you trying to align points in two similar layers?
AdrianWelsh
No, I guess I did not read far enough on align features. I don't want to move any features, just tack on the appropriate attributes based on a location and a matching attribute field. Thanks for the follow up!
DanLee
I see. No problem!
