Opening a python toolbox causes ArcGIS Pro to crash
2925
03-03-2022 01:38 PM
ccowin_odfw
I've written a python toolbox that can take several formats of inputs from various GPS Collars and then conforms everything so it can easily be appended to the main database. Everything in the script seems to be working correctly when I run it in the IDE. However I recently started to do my last round of testing and the toolbox has started freaking out. Yesterday it started asking to be repaired over and over. I moved all the code to a new one and the same thing was happening. Then today it started working initially, but eventually when I click on the carrot to expand the toolbox and show the tools it causes the entire program to crash without providing an error.
So that has me a little confused because the program works just fine when run independently but then it is obviously something in the code that it is causing the issue with ArcGIS Pro.
I've included the whole code with a couple very long code blocks removed for length. Any thoughts?
# -*- coding: utf-8 -*-
import datetime
import os
import arcpy
import dbfread
import pandas as pd
class Toolbox(object):
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "Backfill Data Toolbox"
self.alias = "Backfill Data Toolbox"
# List of tool classes associated with this toolbox
self.tools = [Backfill_Data]
class Backfill_Data(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "Backfill Data Tool"
self.description = "Script to process collars data and add it to the Locations Database."
self.canRunInBackground = False
def getParameterInfo(self):
"""Define parameter definitions"""
in_table = arcpy.Parameter(
name='in_table',
displayName='Dbase or Excel Input',
datatype='DEFile',
direction='Input',
parameterType='Required')
in_table.filter.list = ['dbf', 'xlsx', 'xsl', 'csv']
out_gdb = arcpy.Parameter(
name='out_gdb',
displayName='Output to GDB',
datatype='DEWorkspace',
direction='Output',
animal_species = arcpy.Parameter(
name='animal_species',
displayName='Animal Species',
datatype='GPString',
direction='Input',
parameterType='Required',
animal_species.value = 'Wolf'
animal_species.filter.type = 'ValueList'
animal_species.filter.list = ['Mule Deer', 'Elk', 'Pronghorn', 'Big Horn Sheep', 'Wolf']
collar_manufacturer = arcpy.Parameter(
name='collar_manufacturer',
displayName='Collar Manufacturer',
direction='Input',
collar_manufacturer.value = 'Lotek'
collar_manufacturer.filter.type = 'ValueList'
collar_manufacturer.filter.list = ['Vectronix', 'Telonics', 'Sirtrack', 'Lotek', 'Manual Entry', 'Wufoo']
pack = arcpy.Parameter(
name='pack',
displayName=f'Pack',
direction='Input',
parameterType='Optional',
enabled=False)
pack.filter.type = 'ValueList'
pack_list = ['a', 'list', 'of', 'strings']
pack_list.sort()
pack.filter.list = pack_list
entry_staff = arcpy.Parameter(
name='entry_staff',
displayName='Entry Staff',
direction='Input',
enabled=False)
add_adm_location = arcpy.Parameter(
name='add_adm_location',
displayName='Add Administrative Locations (County, WMU, and Ownership)',
datatype='GPBoolean',
direction='Input',
enabled=False)
add_adm_location.value = True
status_table = arcpy.Parameter(
name='status_table',
displayName='Status Inputs',
datatype='GPGAValueTable',
direction='Input',
enabled=False)
status_table.columns = ([['GPString', 'Status'], ['GPDate', 'Start'], ['GPDate', 'End']])
status_table.filters[0].type = 'ValueList'
status_table.filters[0].list = ['InPack', 'Dispersed', 'Roaming']
params = [in_table, out_gdb, animal_species, collar_manufacturer, pack, entry_staff, add_adm_location,
status_table]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
if parameters[2].valueAsText == 'Wolf':
parameters[4].enabled = True
parameters[5].enabled = True
parameters[6].enabled = True
parameters[7].enabled = True
else:
parameters[4].enabled = False
parameters[5].enabled = False
parameters[6].enabled = False
parameters[7].enabled = False
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
return
def xy_to_fc(self, parameters, table_for_xy, output_name, input_format):
collar_manufacturer = parameters[3].valueAsText
output_path = os.path.join(parameters[1].valueAsText, output_name)
# If output exists delete it, sometimes not deleting caused errors when processing it again
if arcpy.Exists(output_path):
arcpy.AddMessage(f'Deleting old feature class: {output_path}...')
arcpy.management.Delete(output_path)
if collar_manufacturer == 'Vectronix':
in_x_field = 'LONGITUDE'
in_y_field = 'LATITUDE'
in_z_field = 'HEIGHT'
elif collar_manufacturer == 'Sirtrack' or collar_manufacturer == 'Telonics':
if input_format == 'csv':
in_x_field = 'Longitude'
in_y_field = 'Latitude'
in_z_field = None
else:
in_x_field = 'Longitude_'
in_y_field = 'Latitude_d'
in_z_field = None
elif collar_manufacturer == 'Lotek':
in_z_field = 'Altitude'
else:
raise Exception('Error in collar_manufacturer parameter.')
# Process: Make XY Event Layer (Make XY Event Layer) (management)
arcpy.AddMessage('Making XY Event Layer...')
xy_event_layer = 'memory/xy_event_layer'
arcpy.management.MakeXYEventLayer(table=table_for_xy,
in_x_field=in_x_field,
in_y_field=in_y_field,
out_layer=xy_event_layer,
spatial_reference=arcpy.SpatialReference(4269),
in_z_field=in_z_field)
# Generate GDB if it doesn't exist
if not arcpy.Exists(os.path.join(parameters[1].valueAsText)):
full_path = parameters[1].valueAsText
full_path_list = full_path.split('\\')
out_folder_path = '\\'.join(full_path_list[:-1])
out_name = full_path_list[-1]
arcpy.AddMessage(out_folder_path)
arcpy.AddMessage(out_name)
arcpy.management.CreateFileGDB(out_folder_path, out_name)
# Process: Feature Class To Feature Class (Feature Class To Feature Class) (conversion)
arcpy.AddMessage('Copying event layer to a feature class...')
arcpy.conversion.FeatureClassToFeatureClass(in_features=xy_event_layer,
out_path=os.path.join(parameters[1].valueAsText),
out_name=output_name,
where_clause="",
config_keyword="")
# Grab original fields to delete later
original_fields = arcpy.ListFields(os.path.join(parameters[1].valueAsText, output_name))
# Calculate Fields:
arcpy.AddMessage('Calculating the Collar_ID field...')
arcpy.management.CalculateField(output_path, 'Collar_ID',
expression=f'!CollarID!',
field_type='TEXT'
elif collar_manufacturer == 'Sirtrack':
expression=f'!Tag_ID!',
field_type='TEXT'
expression='!Device_ID!',
field_type='TEXT'
arcpy.AddMessage('Calculating the Lat_DDeg field...')
arcpy.management.CalculateField(output_path, 'Lat_DDeg',
expression=f'!{in_y_field}!',
field_type='DOUBLE'
arcpy.AddMessage('Calculating the Long_DDeg field...')
arcpy.management.CalculateField(output_path, 'Long_DDeg',
expression=f'!{in_x_field}!',
field_type='DOUBLE'
arcpy.AddMessage('Calculating the LL_Datum field...')
arcpy.management.CalculateField(output_path, 'LL_Datum',
expression="""'WGS84'""",
field_type='TEXT'
arcpy.AddMessage('Calculating the Accuracy field...')
if collar_manufacturer == 'Vectronix' or collar_manufacturer == 'Lotek':
arcpy.management.CalculateField(output_path, 'Accuracy',
expression='dop(!DOP!)',
expression_type='PYTHON 3',
code_block="""def dop(dop):
if dop <= 6:
return "< 20 yds"
elif dop >= 20:
return "250 yds - 1/2 mile"
else:
return "20 - 250 yds"
field_type='TEXT'
arcpy.AddMessage('Calculating the Species field...')
arcpy.management.CalculateField(output_path, 'Species',
expression=f"""'{parameters[2].valueAsText}'""",
field_type='TEXT'
arcpy.AddMessage('Calculating the Type field...')
arcpy.management.CalculateField(output_path, 'Type',
expression="""'Collar data'""",
field_type='TEXT'
arcpy.AddMessage('Calculating the Source field...')
arcpy.management.CalculateField(output_path, 'Source',
expression=f"""'{collar_manufacturer} collar'""",
field_type='TEXT'
arcpy.AddMessage('Calculating the Entry_Staff field from the Entry_Staff parameter...')
arcpy.management.CalculateField(output_path, 'Entry_Staff',
expression=f"""'{parameters[5].valueAsText}'""",
field_type='TEXT'
arcpy.AddMessage('Calculating the Entry_Date field...')
arcpy.management.CalculateField(output_path, 'Entry_Date',
expression=f"""'{datetime.datetime.now().strftime('%d/%m/%Y')}'""",
field_type='DATE'
arcpy.AddMessage('Calculating the Visual field...')
arcpy.management.CalculateField(output_path, 'Visual',
expression="""'No'""",
field_type='TEXT'
arcpy.AddMessage('Adding the Pack field from the Pack parameter...')
arcpy.management.CalculateField(output_path, 'Pack',
expression=f"""'{parameters[4].valueAsText}'""",
field_type='TEXT'
if parameters[3].valueAsText == 'Vectronix':
arcpy.AddMessage('Adding the Wolf_Name field from the CollarID field...')
arcpy.management.CalculateField(output_path, 'Wolf_Name',
expression=f"""'name(!CollarID!)'""",
code_block="""def name(collar_id):
really long if statement that didnt need to be included""",
field_type='TEXT'
arcpy.AddMessage('Adding the Wolf ID field from the Wolf_Name field...')
arcpy.management.CalculateField(output_path, 'Wolf_ID',
expression=f"""'id(!Wolf_Name!)'""",
code_block="""def id(wolf_name):
field_type='TEXT'
elif collar_manufacturer == 'Sirtracks':
arcpy.AddMessage('Wolf_Name and Wolf_ID are null for Sirtracks data, please add manually.')
expression=f'!IndividualName!',
field_type='TEXT'
# Calculate all Date Fields:
arcpy.AddMessage('Calculating the UTC field...')
arcpy.management.CalculateField(output_path, 'UTC',
expression='uct(!UTC_DATE!, "!UTC_TIME!")',
code_block="""def uct(date, time):
date_str = date.strftime('%m/%d/%Y')
datetime_str = date_str + ' ' + time
dt = datetime.datetime.strptime(datetime_str, '%m/%d/%Y %H:%M:%S')
return dt
field_type='DATE'
elif parameters[3].valueAsText == 'Sirtrack':
expression='utc(!UTC_Date!, "!UTC_Time!")',
code_block="""def utc(date, time):
return dt
field_type='DATE'
elif parameters[3].valueAsText == 'Telonics':
expression='utc(!ObservationDateTimePST!)',
code_block="""def utc(pst):
import pytz
pst.replace(tzinfo=pytz.timezone('America/Los_Angeles'))
utc = pst.astimezone(pytz.timezone('Europe/London'))
return utc
field_type='DATE'
elif parameters[3].valueAsText == 'Lotek':
expression='!Date___Tim!',
code_block="""""",
field_type='DATE'
arcpy.AddMessage('Calculating the PST and PDT fields from the UTC field...')
arcpy.management.ConvertTimeZone(output_path, 'UTC', 'UTC', 'PST', 'Pacific_Standard_Time', False, False)
arcpy.management.ConvertTimeZone(output_path, 'UTC', 'UTC', 'PDT', 'Pacific_Standard_Time', False, True)
arcpy.AddMessage('Calculating the Start_Time field...')
arcpy.management.CalculateField(output_path, 'Start_Time',
expression='!PST!',
field_type='DATE'
arcpy.AddMessage('Calculating the End_Time field...')
arcpy.management.AddField(output_path, 'End_Time', 'DATE')
arcpy.management.CalculateEndTime(output_path, 'Start_Time', 'End_Time')
arcpy.AddMessage('Calculating the TimeInt field...')
arcpy.management.CalculateField(output_path, 'TimeInt',
expression='time_diff(!Start_Time!, !End_Time!)',
code_block="""def time_diff(start, end):
diff = end - start
return diff.seconds//60
field_type='LONG'
# Switch output to target now that the ultimate feature class has been created.
target_features = output_path
# Spatially join administrative boundaries: WMU, County, and Ownership
if parameters[6].value and parameters[2].valueAsText == 'Wolf':
ownership_input = r'some network path'
ownership_ouput = r'memory\OwnershipIntermediate'
wmu_input = r'some network path'
wmu_output = r'memory\WMUIntermediate'
county_input = r'some network path'
county_output = r'memory\CountiesIntermediate'
arcpy.AddMessage('Calculating Ownership...')
arcpy.analysis.SpatialJoin(target_features=target_features, join_features=ownership_input,
out_feature_class=ownership_ouput, join_operation="JOIN_ONE_TO_ONE",
join_type="KEEP_ALL", field_mapping="", match_option="INTERSECT",
search_radius="", distance_field_name="")
arcpy.management.JoinField(in_data=target_features, in_field="OBJECTID", join_table=ownership_ouput,
join_field="TARGET_FID", fields=["OWN_TYPE"])
arcpy.management.CalculateField(in_table=target_features, field="Ownership", expression='func(!OWN_TYPE!)',
expression_type="PYTHON3",
code_block="""def func(own):
if own:
return own
else:
return 'Outside Oregon'""",
field_type="TEXT",
enforce_domains="NO_ENFORCE_DOMAINS")
arcpy.AddMessage('Calculating County...')
arcpy.analysis.SpatialJoin(target_features=target_features, join_features=county_input,
out_feature_class=county_output, join_operation="JOIN_ONE_TO_ONE",
arcpy.management.JoinField(in_data=target_features, in_field="OBJECTID", join_table=county_output,
join_field="TARGET_FID", fields=["Name"])
arcpy.management.CalculateField(in_table=target_features, field='County', expression='func(!Name!)',
expression_type='PYTHON3',
code_block="""def func(county):
if county:
return county
else:
field_type='TEXT',
enforce_domains='NO_ENFORCE_DOMAINS')
arcpy.AddMessage('Calculating WMU...')
arcpy.analysis.SpatialJoin(target_features=target_features, join_features=wmu_input,
out_feature_class=wmu_output, join_operation='JOIN_ONE_TO_ONE',
join_type='KEEP_ALL', field_mapping='', match_option='INTERSECT',
search_radius='', distance_field_name='')
arcpy.management.JoinField(in_data=target_features, in_field='OBJECTID', join_table=wmu_output,
join_field='TARGET_FID', fields=['UNIT_NAME'])
arcpy.management.CalculateField(in_table=target_features, field='WMU', expression='func(!UNIT_NAME!)',
code_block="""def func(wmu):
if wmu:
return wmu
else:
field_type='TEXT',
arcpy.management.DeleteField(target_features, 'OWN_TYPE')
arcpy.management.DeleteField(target_features, 'NAME')
arcpy.management.DeleteField(target_features, 'UNIT_NAME')
if parameters[7].value:
# Adding Status field based on input from the Status Table parameter.
arcpy.AddMessage('Calculating Status field from the Status Table parameter...')
fields_list = arcpy.ListFields(target_features)
for field in fields_list:
if 'Status' not in field.name:
arcpy.management.AddField(target_features, "Status", "TEXT")
st = parameters[7].valueAsText
arcpy.AddMessage(st)
st_split = st.split(";")
fields = ["Status", "Start_Time"]
for entry in st_split:
entry_split = entry.split(" ")
status = entry_split[0]
start_time = entry_split[1]
end_time = entry_split[2]
sql = f"Start_Time >= date '{start_time}' AND Start_Time <= date '{end_time}'"
with arcpy.da.UpdateCursor(target_features, fields, sql) as cursor:
for row in cursor:
row[0] = status
cursor.updateRow(row)
else:
arcpy.AddMessage('Add Administrative Boundaries not selected...')
# Delete unused fields:
arcpy.AddMessage('Deleting unused fields...')
for field in original_fields:
if not field.required:
arcpy.management.DeleteField(output_path, field.name)
def execute(self, parameters, messages):
# """The source code of the tool."""
input_format = parameters[0].valueAsText.split('.')[-1].lower()
scratch = arcpy.env.scratchFolder
if input_format in ['xlsx', 'xls', 'csv', 'dbf', 'txt']:
arcpy.AddMessage(f'File detected as {input_format}, Converting {input_format} to Table')
input_path = os.path.join(parameters[0].valueAsText)
if input_format == 'dbf':
dbf = dbfread.DBF(input_path)
df = pd.DataFrame(iter(dbf))
table_for_xy = os.path.join(parameters[0].valueAsText)
elif input_format == 'csv':
excel_path = os.path.join(parameters[0].valueAsText[:-3] + 'xlsx')
df = pd.read_csv(input_path)
df = df.rename(columns={df.columns[0]: 'Device_ID'})
df.to_excel(excel_path, index=False, columns=['Device_ID', 'Date & Time [GMT]', 'Latitude', 'Longitude',
'Altitude', 'DOP'])
table_for_xy = arcpy.conversion.ExcelToTable(excel_path, scratch)
elif input_format == 'txt':
df = pd.read_table(input_path)
table_for_xy = arcpy.conversion.TableToTable(input_path, scratch, 'TempTxtTable')
elif input_format == 'xlsx' or input_format == 'xls':
df = pd.read_excel(input_path)
table_for_xy = arcpy.conversion.ExcelToTable(input_path, scratch)
else:
raise Exception('Incorrect format of input file.')
# Build list of all unique Collar ID values that will be used to make a selection so all the data is
# processed at the same time
if collar_manufacturer == 'Vectronix' or collar_manufacturer == 'Telonics':
collar_list = df.CollarID.unique()
collar_list = df.Tag_ID.unique()
collar_list = df['Device_ID'].unique()
else:
raise Exception('Collar Manufacturer doesnt match.')
if len(collar_list) != 0:
counter = 0
for collar_id in collar_list:
counter = counter + 1
arcpy.AddMessage(f'Processing {collar_id}, {counter} of {len(collar_list)}...')
subframe = df[df[f'CollarID'] == collar_id]
min_date = subframe.UTC_DATE.min().strftime('%y%m%d')
max_date = subframe.UTC_DATE.max().strftime('%y%m%d')
output_name = f'{collar_manufacturer[0].upper()}_{collar_id}_{min_date}_{max_date}'
selection = arcpy.management.SelectLayerByAttribute(table_for_xy, 'NEW_SELECTION',
f"""CollarID = {collar_id}""")
df['UTC'] = df[['UTC_Date', 'UTC_Time']].agg(' '.join, axis=1)
df['UTC'] = pd.to_datetime(df['UTC'], format='%m/%d/%Y %H:%M:%S')
subframe = df[df[f'Tag_ID'] == collar_id]
min_date = subframe.UTC.min().strftime('%y%m%d')
max_date = subframe.UTC.max().strftime('%y%m%d')
selection = arcpy.management.SelectLayerByAttribute(table_for_xy, 'NEW_SELECTION', f"""Tag_ID = '{collar_id} And Latitude <> 0 And Longitude <> 0'""")
elif collar_manufacturer == 'Telonics':
min_date = subframe.ObservationDateTimePST.min().strftime('%y%m%d')
max_date = subframe.ObservationDateTimePST.max().strftime('%y%m%d')
selection = arcpy.management.SelectLayerByAttribute(table_for_xy, 'NEW_SELECTION', f"""Tag_ID = '{collar_id}' And Latitude <> 0 And Longitude <> 0""")
if 'UTC' not in df.columns:
df['UTC'] = pd.to_datetime(df['Date & Time [GMT]'], format='%Y-%m-%d %H:%M:%S')
subframe = df[df['Device_ID'] == collar_id]
selection = arcpy.management.SelectLayerByAttribute(table_for_xy, 'NEW_SELECTION', f"""Device_ID = {collar_id} And Latitude <> 0 And Longitude <> 0""")
selection = arcpy.conversion.TableToTable(selection, 'memory', output_name)
else:
self.xy_to_fc(parameters=parameters, table_for_xy=selection, output_name=output_name,
input_format=input_format)
else:
raise Exception('No Collar ID in Table.')
else:
arcpy.AddMessage(
f'File detected as {input_format}, this format is unsupported. Please use dbf, xlsx or xls')
raise Exception('Invalid input table format!')
arcpy.AddMessage('Data processing is complete!')
# This allows the script to be run independently of ArcGIS Pro or ArcGIS for Desktop to leverage debugging tools
def main():
# tbx = Toolbox()
tool = Backfill_Data()
tool.execute(tool.getParameterInfo(), None)
if __name__ == '__main__':
main()
by Anonymous User
Not applicable
A bit of a guess, but I think that this is the problem:
def main():
    # tbx = Toolbox()
    main()
You're mixing the ways that Pro expects to get input from a Python toolbox, and you're polluting the namespace that Pro is relying on to convert code into GUI. Perhaps I haven't found the right docs to explain it, but the way ArcMap and Pro execute Python under the hood always seems to have unexpected consequences.
I'd delete this code block and then conform your code to ESRI's template (which you're already using otherwise).
by Anonymous User
Not applicable
def main():
    # tbx = Toolbox()
    main()
Reinaldo_Cartagena
Your python script has sistanxis and semantic problems in the Python_Toolbox.pyt, it can alter your script, open and run in ArcGIS Pro 2.9.2 see image. I recommend you to create a new New_Python_Toolbox.pyt, correct the problem with the dbfread module and use the modified attached scripts as reference.
import datetime
import os
import arcpy
import pandas as pd
#import dbfread
    def __init__(self):
        .pyt file)."""
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
            name='in_table',
            datatype='DEFile',
            direction='Input',
            name='out_gdb',
            direction='Output',
            direction='Input',
            direction='Input',
            name='pack',
            direction='Input',
            enabled=False)
        pack_list.sort()
            name='entry_staff',
            direction='Input',
            enabled=False)
            direction='Input',
            enabled=False)
            direction='Input',
            enabled=False)
                  status_table]
        return params
        return True
        else:
        return
        return
                in_z_field = None
            else:
                in_z_field = None
        else:
                                                    where_clause="",
                                                    config_keyword="")
        # Calculate Fields:
                                            field_type='TEXT'
                                            field_type='TEXT'
                                            field_type='TEXT'
                                        field_type='DOUBLE'
                                        field_type='DOUBLE'
                                        field_type='TEXT'
                                                            if dop <= 6:
        return "< 20 yds"
                                                            elif dop >= 20:
                                                            else:
                                            field_type='TEXT'
                                        field_type='TEXT'
                                        field_type='TEXT'
                                        field_type='TEXT'
                                        field_type='TEXT'
                                        field_type='DATE'
                                        field_type='TEXT'
                                            field_type='TEXT'
                                                field_type='TEXT'
                                                field_type='TEXT'
                                                field_type='TEXT'
                                                            return dt
                                            field_type='DATE'
                                                            return dt
                                            field_type='DATE'
                                                            import pytz
                                                            return utc
                                            field_type='DATE'
                                            code_block="""""",
                                            field_type='DATE'
                                        expression='!PST!',
                                        field_type='DATE'
                                                        diff = end - start
                                        field_type='LONG'
                                                            if own:
        return own
                                                            else:
                                            field_type="TEXT",
                                                            if county:
        return county
                                                            else:
                                            field_type='TEXT',
                                                            if wmu:
        return wmu
                                                            else:
                                            field_type='TEXT',
                        for row in cursor:
                            row[0] = status
        else:
                                                              'Altitude', 'DOP'])
            else:
            else:
                counter = 0
                    else:
            else:
        else:
            arcpy.AddMessage(
        return
