Number of points for geodesic viewshed
724
09-26-2023 05:52 AM
mody_buchbinder
Is there any limit to the number of points we give to geodesic viewshed if we use the frequency type?
Will it get 100? maybe 1000?
If you give it a line, is it splitting it to points and by what distance?
We try to get viewshed alone line but we need to understand the resolution of the analysis
Thanks
DanPatterson
MVP Esteemed Contributor
How Geodesic Viewshed works—ArcGIS Pro | Documentation
This is what it says:
It also optionally produces an observer-region relationship table for up to 32 observers (points, multipoints, or polylines) that can be related back to the input observer feature class.
Are you finding a difference? or are you getting an error? or did you try?
... sort of retired...
mody_buchbinder
Hi Dan
This limit is because when you use the Observers option and the pixel have 32 bit only then you cannot save more then 32 point result.
Because of this we tried the Frequency option. It did not gave any error message it just ignored some points.
