No preview Maps at the beginning of startup ArcGIS Pro ?
1010
12-07-2022 09:34 AM
DEAF_PROBERT_68
Honored Contributor
Hello,
As I am resuming working on a new project, or if you are trying to clean up your projects.  I was wondering why there was no Preview map to review the past maps. If you recall ArcGIS ArcMap, it has the enable to turn on the thumbnails to view each map?
Why was there no tab to switch from list to preview when you open your ArcGIS Pro and at the left menu under Open. All you can is see the list with the project path?
Are there any plans ESRI will implement on that for the next new version in the future?
wayfaringrob
Honored Contributor
Probably because a project can have more than one layout/map? Not sure but I do miss having those tiles for quick scanning, especially when I'm looking to copy something over for cartographic purposes and I don't really remember which project it was used in.
Robert_LeClair
Esri Esteemed Contributor
Looks like this is an ArcGIS Idea submitted 7/18/2019 here and is under consideration for a future release.
DEAF_PROBERT_68
Honored Contributor
Robert, Thank you for that info.  I search for it but came up none until you share that info.
