My default geodatabase is empty in ArcGIS Pro but in the folder location shows >20GB
1018
10-24-2023 01:15 AM
AndrewHankinson
I had a corrupted geodatabase and so have created a new one and migrated all the data from the corrupted geodatabase to the new one.
I have also made the new one the default.
The old corrupted geodatabase is all but empty excepty for a trace network I can't delete, however the folder location of the corrupted geodatabase shows as >20GB.
I have tried compacting the corrupted geodatabase but the size stays the same.
Why would the folder location still be showing such a high GB if the geodatabase is all but empty? Is it possible to just delete the folder or the contents of the folder?
Andy
Robert_LeClair
Esri Esteemed Contributor
One workflow to consider if the project default geodatabase is corrupt is to simply delete the entire ArcGIS Pro project folder if you don't need the *.aprx at all.  If you can recreate the project in a new *.aprx, then that would be the fastest way to resolve the issue.  Once the new project is created, delete the old folder system/project.
