Multiple Layout Views showing different results from one feature layer
1399
02-12-2025 01:25 PM
southborough_gis
I am new to GIS so I am sure this is a basic question.  I have a map of various plow routes in town. I am creating multiple Layouts in ArcGIS Pro 3.4 to show each individual plow route on a map.  Each page has a legend with the Drivers Name and symbol..  I am struggling to show each layout with different data and each legend with just the data for that layout.  Any help is apprecaited.
AlfredBaldenweck
MVP Frequent Contributor
Yes, absolutely. Check out Page queries in a spatial map series—ArcGIS Pro | Documentation
You can set each layer to show either things that match or don't match the value of the index feature's name.
AlfredBaldenweck
You should look into Map Series
Map series—ArcGIS Pro | Documentation
A spatial map series will cycle through each record in the index layer (that you feed it), so you get a page for each one.
One caveat is that the layout is EXACTLY the same for each page.
southborough_gis
Hi Alfred Thank you - I played around with this as it pertains to a different set of plans and understand the concept.  Is it possible to only show the pertinent feature on each sheet? for example - I probably have 50 plow routes in town.  I want the output to only show the relevant plow route on the map (for example Route1) Route 2 wouldn't show on the map at all even though areas of route 2 extend onto the frame area.
AlfredBaldenweck
southborough_gis
Excellent - Thank you.
