multipatch feature disappears when editing
5955
12
04-06-2020 02:23 PM
JustinJohnston
When I try to edit a multipatch feature with edit vertices, it disappears.  I can edit using scale fine, but edit vertices makes it disappear.  See screen capture MP4 attached for what I mean.  It isn't just hiding below the ground surface.  It seems to be gone.
Cheers,
Justin
JacobAalfs
4 years later and still no resolution, except to open dataset in another project. Thanks esri!
JacobAalfs
Opened in another project and it still disappears when trying to edit. KUDOS esri !!!!
JacobAalfs
After pulling my hair out and a lot of cussing while waiting for esri "customer service" (and I use that term, lightly) to call me back, I have discovered it has something to do with setting the elevation of the multipatch feature to "On the ground". I turned off the WorldElevation3D/Terrain3D elevation surface mid-edit and the selected feature is visible.
