Modify Panes for Tabs to be on Top
1764
5
08-12-2022 08:55 AM
Labels (2)
tjh6359
I am wondering if there is a way to customize the pane layout. I would like the tabs with the name of each pane on top, rather than on bottom. I use Adobe products and find the layout with these tabs on top much more intuitive, since going all the way to the bottom of the pane each time is a hassle, especially when my cursor is hardly ever in that space.
Please see the attached picture which should provide my question with more clarity. Thank you.
DanPatterson
No.  Post it as an "Idea".
... sort of retired...
tjh6359
I'm sorry I am very new this. What exactly is your meaning?
Brian_Wilson
Honored Contributor
Dan means go here https://community.esri.com/t5/arcgis-pro-ideas/idb-p/arcgis-pro-ideas and post your suggestion as an idea. People can vote on it, and if Esri likes it enough they might implement it some day.
tjh6359
Roger that and will do. Thanks Brian.
BarryNorthey
Not the solution you were looking for but you can drop panes over target arrows and they will auto hide on that side of the display. You can also right click on any hidden tab to open a pick list of tabs on that side.
