So I'm trying to help a coworker out and create a model for them that will process some tables from GPS Collars into feature classes with some light data processing. It has been incredibly frustrating getting this to work because the model I create in my PC doesn't seem to function, basically at all, on their PC. The table will be entirely null, rows will be deleted, and there are random errors that appear on hers but do not appear on mine (000539 among others). Our versions are slightly different, I'm on 2.9 and they are on 2.10, but I would be shocked if these geoprocessing things have changed.
Another oddity is on their instance of ArcGIS Pro when I go to select a field in Calculate Field it changes the name of the field by adding the name of the table before the name of the field. Say your table is called WA104_ExcelToTable and your field is called Collar_ID; when you go to select the field name in the list it will say Collar_ID but in the expression or code block it produces !WA104_ExcelToTable_Collar_ID!. Why is it doing this?
I've tried it with two different models and the same thing is happening. Here is the simpler of the two:
A few things to consider:
Just some ideas, I hope they may help somewhat.
