Missing Subtypes when Export a Feature Class from SDE
1788
12-13-2021 02:22 AM
Abdullah_AlFazari
Kindly, Using ArcGIS Pro 2.8 I'm trying to export the feature class from SDE to FGDB using the tool (Feature Class to Geodatabase). Unfortunately, the output comes without the subtypes which are mainly in the description of the Subtype. it just the numbers of codes
I tried with ArcMap10.8 using the same tool and it worked well.
and this how the data looks like in subtype.
Any thoughts to solve the issue in the Pro?
DanPatterson
Transfer field domain descriptions (Environment setting)—ArcGIS Pro | Documentation what was the Environments tab set to when you used the tool?
... sort of retired...
DanPatterson
Abdullah_AlFazari
Dear Dan,
Thank you very much. Highly appreciated your solution. It worked well=)
