Metadata Issue in ArcGIS Pro
1106
01-03-2020 05:39 AM
JasonLearned
I am using ArcGIS Pro version 2.4.2, and have been creating new metadata for the datasets and feature classes in the GDB. The metadata format being used is FGDC CSDGM.
I have entered metadata in various fields, saved it, come back to edit, to find that some of the metadata fields are now empty, and in some cases, all of the metadata has been erased somehow.
I'm the only one who has access to edit this GDB. This has happened on several occasions now.
Is this a known issue with ArcGIS Pro, or is there another cause?
Thank you.
JessicaJThompson
I just had this issue. Did you ever figure out what had happened? And is there a way to reverse it?
