Mean value in classification statistics differs from source statistics?
856
01-27-2021 12:32 PM
cp_0101
The minimum and maximum values shown under in the dataset's source tab under statistics matches the max & min in the classification statistics. However, the mean values are different. How can this be?
DavidPike
MVP Frequent Contributor
Perhaps try Calculate Statistics (Data Management)—ArcGIS Pro | Documentation if the current skip factor you have is other than 1.
cp_0101
I don't think I need to set a skip factor, I would like all data in this raster to be evaluated.
DavidPike
Yep, I didn't suggest that.  The skip factor on your dataset stats is listed in the properties, if it's other than 1 - perhaps try the tool.  Some screengrabs might help others to better identify the issue also.
cp_0101
I'm unfamiliar with skip factors, but I attached my stats and from what I can tell my skip factor is 1. Can you please confirm?
DanPatterson
MVP Esteemed Contributor
What is the difference?
What about nodata values?
... sort of retired...
