Map Layout Cordinate System
6278
6
07-10-2021 11:09 AM
Labels (2)
FyneAde-Amadi
Please can anyone help me on how to insert projection on a map layout in ArcGIS Pro. I could only insert other map elements but no projection.
JayantaPoddar
MVP Alum
Are you looking to add the map element of Spatial Reference to your layout? (Insert tab > Dynamic Text > Map FrameSpatial Reference)?
Think Location
DanPatterson
you can't insert a projection into a layout only a map.  That map will have its own projection
... sort of retired...
FyneAde-Amadi
Yes you can insert into a map layout when creating it along with other map elements like north arrow, scale etc. I'm new to ArcGIS Pro so not seeing it among other elements.
DanPatterson
The projection is from the inserted map.  If you want to convey the information on the layout, add a text element specifying what it is.
AubriOtis
Hi!
Once you've added a map to a layout using a map frame, you can change its projection.
To do this, right-click the Map in the Contents Pane and choose properties
Then adjust the coordinate system on the Map Properties window that appears. It is important to know that if you change the map coordinate system in the layout, it is also changed in the map view and vice versa. Map frames on layouts just reflect the map.
Cheers,
Aubri
JayantaPoddar
MVP Alum
Think Location
FyneAde-Amadi
Thanks a lot. Figured it out.
