Map does not display in Layout - ArcGIS Pro 3
31116
20
08-24-2022 09:45 AM
SujanDS
Map frame is blank in layout. The data is visible in the map view but when I add the map frame to the layout, I see a white box only.
ECC_Maps
Was there ever any solution to this problem? I have this exact bug since I just updated to ArcGIS Pro 3, where the map displays in a layout as blank if there are any layers with layers blends activated. Set them to normal, map reappears.  It's repeatable across projects. I can export the map, blank frame and it will be in the exported file, but I cannot see for working on map while in layout, which severely complicates production.
JeremyWright
We have discovered a negative interaction between map frame clipping and blend modes, which we are working on resolving at present.  Can you confirm whether your map has any Layer clipping enabled?  This would be in the map properties under Clip Layers.
If you do have clipping, and you disable it, does the map frame then draw?
bergmanncolin
@JeremyWright Was there ever a fix for this? I just updated to ArcGIS Pro 3 and am experiencing the same issue. As soon as I turn layer blending on everything in the map frame disappears.
JeremyWright
ArcGIS Pro 3.1 release resolves these issues with blend modes
NIck_WGNHS
@JeremyWright , I have been encountering the same issues with blend layers preventing the map frame from displaying in the layout.  I can confirm that I am using clipping with the map frame.
JeremyWright
All, there is a fix forthcoming for this in the next release of ArcGIS Pro.
CRose
I am using both Blend Modes and Clip to Outline in my project. My Map Frames in Layouts all appear empty when viewing in Pro they do export to PDF and print ok though. I hope there will be a fix soon.
JeremyWright
The resolution for this issue will be in the next release of ArcGIS Pro (3.1)
JeremyWright
UPDATE: ArcGIS Pro 3.1 (out now) resolves this issue.
Md_AsifHasan
I have updated to the latest version of ArcGIS Pro (3.1 version, June, 2023), but still facing this problem
