MakeQueryLayer retrives some integers as 0
1361
08-18-2022 01:30 PM
DiegoMonge_Chinchilla
Hello everyone
I´m trying to do a MakeQueryLayer with ArcGIS PRO 3.0.1 and it works as expected.
The problem is when I tried to do it in ArcPy and I get Integer Columns as 0 instead of the real value.
I´m using a .sde file conected to a Oracle data base using the instant client 21.06
This is how I get the data using ArcGIS PRO interface (everything looks fine):
This is how I get the data using Arcpy on the Notebook, ArcGIS PRO console or using the python.exe enviroment:
This is my code:
conexion_oracle = '\conexion_oracle.sde'
query = "select ID_VISITA_TECNICA, CAST(ANIO AS INT) AS ANIO, IDENTIFICACION, PRODUCTOR, REGIONAL, CICLO, N, AREA_APLICADA, PESO_SACO, CANTIDAD_SACOS from CRCAFE.ICFSIG_VISITAS_FERTILIZANTES_VW"
arcpy.management.MakeQueryLayer(conexion_oracle, 'fertilizantes', query, 'ID_VISITA_TECNICA')
Any help will be appreciated.
Thanks
DanPatterson
MVP Esteemed Contributor
Are those two columns numbers expressed as text/string values? or are they just left justified?
... sort of retired...
Hello Dan
Those colums are Integers
DanPatterson
strange... it is almost like the justification has interpreted it as non-integer... try changing the justification in the source columns first otherwise, Tech Support might be your best bet
