Make elements same width, size, distribute not working
1698
6
08-17-2024 12:51 PM
AvaFarouche
Hello!
I'm trying to make two elements the same width and can't make it happen. I'm using two legends on one layout - which is something I do often and this is the first time I've had this problem.
I cannot get these two to be the same width. In the legend settings, I've set the same width specifications, but they clearly aren't the same width. I've set all of the fonts the same sizes. I've selected both legends, right-clicked, and went to distribute/ make same size and make same width. Nothing. I tried just selecting each in turn and dragging the borders. It just moves the whole legend, but won't change the size of it. Of course I also tried restarting the software and restarting my computer. Nothing.
Any ideas?  Thank you!!!
BarryNorthey
Save your Project in case things go south.
  • For each Legend --> Pick a suitable Legend Arrangement Option in the Element pane besides Adjust frame
  • Set the element's width
AvaFarouche
Thanks for the suggestion! I already tried that. That's where I set the widths to be the same in both legends, and they're still not the same.
BarryNorthey
This might do it:
  • Select both Legend frames. This opens a Legend tab.
    in the Size and Position group.
AubriOtis
That's really frustrating, and I'm sorry it's happening. Can you show the legends and the legend settings? There are a lot of things that can be changed for legends, a little more information on how your legends are set up would be really useful.
Cheers,
Aubri
AvaFarouche
Thanks, Aubri!
I eventually got it to work. I didn't do anything different, I just tried the same things I had already done a bunch of times and it finally worked. I think there must have just been some sort of glitch.
AubriOtis
I'm really sorry about that, but I'm glad it's working now.
Cheers,
Aubri
