LYRX with feature server as data source doesnt refresh!
518
05-02-2025 12:17 PM
Bharat
Hi All,
so, we have a layer's folder containing many lyrx files. All these layers files use published feature server as data source and of course some query definition.
Recently we added new field to one of the published feature classes, we had to reorder the fields and once we overwrite, we can see the order of the field is indeed correct via rest url.
Now the layers that uses this published feature class as data source still shows the same old field order, moreover this new added field is at the very end/right. Seems like this lyrx file is still using the same old schema as checked via text editor.
Our layers files have any custom icon, now what I can do is import the feature server to the map, change symbology for each sub layers, basically have to redo everything. Why is it so and why do I have to manually updates 98 of these layers files which contains arounds 200 feautres layers in total.
What am i missing? The source of the layers remains the same and what's the point of keeping the rest url as source if it won't fetch/ refresh the schema (it does shows all the latest rows)
LYRX source point to the FS
LYRX fields, you can see it's at bottom
REST URL
