Layer to KML only shows all attributes in popup
1097
08-25-2022 10:01 AM
BenjaminBlackshear
The Layer to KML tool is not functioning as described in the documentation KML conversion—ArcGIS Pro | Documentation
Once I add the folderPath field to the data I lose my popup configuration in the output KMZ and it will only show all of the attributes.
Before adding the folderPath field, the output KMZ popup would match the visible fields set in the attribute table.
I think this is a bug.
I am using ArcGIS Pro 2.9.3
by Anonymous User
Not applicable
This isn't working for me either. The documentation doesn't seem to match what the actual exports are.
BenSundy
This still isn't working in 3.2.0
