KML to Layer Issue- Is what I'm doing supported?
13534
16
02-11-2022 07:33 AM
Labels (2)
jdruding
I'm evaluating ArcGIS for personal use and so Esri won't answer my question as to whether this is supported or not and directed me here.   I would like to be able to import KML/KMZ with embedded photos.  These KMZ files have tracks and points with photos attached to them and are created in an app called GaiaGPS.  I know that the KMZ file is valid because it works as expected if you import it to Google Earth.  (the tracks are imported and the points have the photos attached properly)
I'm using the KML to Layer conversion tool and checking the box to "Include Ground Overlay". The import imports the points and polylines, but when I click on a point with a photo, the pop up shows the image link is broken.  Looking at the values in the pop up field, I can see that it references the photo with format of:
"<img src="ae297b388e83811290459c4cfb6f6c8d.jpg">"
When looking at the size of the geodatabase, it is clear that the photos are not present after import. (i.e. the geodatabase is very tiny and the original KMZ is 50 MB.)  I would have thought that KML to Layer function would either copy the photos to a location relative to the root of the reference above (the geodatabase folder itself?) or automatically configure the image element in the Pop Up.
Is this functionality supported?
Robert_LeClair
Esri Esteemed Contributor
To my knowledge, no.  There is an Enhancement Request (NIM086198) - "Images in pop-ups from KML are not maintained with the KML to Layer geoprocessing tool."  Wish I had better information for you.
Robert_LeClair
Good morning - you are correct that the ArcGIS for Personal Use program does not have access to Esri Support Services but the Esri Community forum is a great resource that is monitored by Esri staff so we can assist here.  With regard to your question, are you able to share the *.kmz so I can test some workflows on my side?
jdruding
Thanks Robert!  The file is too large to attach the entire thing and, besides, it is little too sensitive for me to post publicly.  (you could pretty easily find my home, for instance)  So, I extracted a single track that has points and photos.  NOTE: KMZ files are blocked from upload so I changed the file extension to .ZIP
Robert_LeClair
Thx!  I've downloaded the file and am working with it now in ArcGIS Pro 2.9.1.  Natively the *.kmz works just fine in ArcGIS Pro with no data conversion required.  I can click on "My Photo - 1/23/22, time" and see the photos just fine.  See attached.  I'll try converting it to a geodatabase feature class and report my findings.
jdruding
That's great, so it obviously can be done.  Im using 2.9.1 also and my import looks just like yours EXCEPT, in the pop up your are showing, I see a broken link icon instead of the picture.  Attached is a pic.
MichaelBodziak
How did you complete this correctly?? I have a kml file with pictures and I cannot get them to convert to a GDB feature with Picture.
Robert_LeClair
Right - so I did not run the KML to Layer GP tool at all and just added the *.kmz right to a new Map View.  If I run the KML to Layer GP tool, then I see the same thing that you do.  Click the Add Data button in the Layer group on the Map core tab and add the *.kmz right to your map.  Does it mimic my screen grab earlier?
jdruding
You rock, Robert!  That worked!  Thanks!
jdruding
Hi @Robert_LeClair , I'm back again.  🙂   So this solution solved my first problem of showing the photos, but as soon as started playing around with it, I realized it didn't really solve my original task of importing the KML/KMZ data into the ArcGIS geodatabase.  This method created a KML Layer, which is obviously limited in its capabilities.  Is there a way to now save this data into a new ArcGIS layer? Or back to the original question, is there a way to make it work with KML to Layer?
Robert_LeClair
