Kml to layer failed
6808
05-10-2023 11:05 PM
Burakkucuk
Hello,
I have a problem with my KML layer. I tried to convert kml layers to feature class. I used "Kml to layer" tool. However, I clicked the Run button, there was a warning message and the message is "WARNING 000401: No features were found for processing" like that.
Kml layers converted from feature class before. I wanted to convert this kml to feature class again, it failed. Thank you.
Burakkucuk
Hello again,
I investigated the problem and found something. I guess, there is a bug report about this issue.
https://support.esri.com/en-us/bug/the-kml-to-layer-tool-returns-the-following-error-error-bug-00010...
I accepted this issue is closed. Thank you for attention.
DanielFox1
Hi @Burakkucuk
Have you reviewed the documentation surrounding the error message you are getting?
000401: No features were found for processing.
What is different between this kml compared to others in the past, is it the same source?
What version of ArcGIS Pro are you using?
Burakkucuk
Hello,
I checked the document you linked and ı have no problem with this. I tried to "Feature Class to Feature Class" tool for my kml layer and it works.
If ı tried to run "Kml to layer" tool, the parameter of output location normally see geodatabases i think. But, the tool can't see geodatabases and because of that the problem occured. Pro version is 3.1.1
Actually, I didn't realize the differences of kml layers to others.
Burakkucuk
Hello again,
