Joining a excel table to feature class
1508
11-14-2024 12:07 PM
DevarsiMajumder
Hello there
I am trying to add some new fields from an Excel sheet to a new feature class. The Excel file already has the new fields built in, and I was wondering if there is a way that I can join that table to the feature class without having a common ID field. Or do I need to build a common field in Excel to join the feature class? Can I just add the four fields from Excel to the feature class?
2 Solutions
clt_cabq
does your excel data have any coordinate information? you could try doing something spatial, but that may end up not working real well if the coordinate data aren't quite right. Your best approach is to spend the effort to create some sort of linking field in the excel table I think otherwise there is just no real way to connect common rows between data sources. How are you able to know which row in excel belongs to which row in your feature class?
DevarsiMajumder
Yeah I decided to put all the fields in one feature class and then  make view layers and turn on and turn off certain fields that  are not needed to be seen.  I figured that was the best  solution to my issue.
clt_cabq
DevarsiMajumder
