Is there a way to apply the same colormap to multiple images automatically?
423
11-15-2024 09:07 AM
SimonCrutchley
Is there a way to apply the same colormap to multiple images automatically? I have large numbers of TIF images from Copernicus representing Soil Water Index values. In order to compare them, these need to use the same colourmap, but at present I have to manually change the symbology for each. I first set the symbology to unique values and then import a stored colormap, but this is very laborious.
I was wondering if there is a way to automate the process. I've tried using model builder, but can't find a way to move through the different files.
Thanks in advance.
BarryNorthey
It looks like you want to use an Iterator in ModelBulder. You might try to iterate over rasters as explained here.
SimonCrutchley
Hi Barry, I'm afraid that I'm very much a novice when it comes to ModelBuilder and I'm afraid I can't follow what is going on in the example and how to make it work for my requirements.
Thanks for your help anyway.
