Issue with trying to use Geoprocessing.ExecuteToolAsync-method in add-in for ArcGIS Pro 2.9
1124
03-08-2022 07:11 AM
PhilipBaggerBenteBent
I am attempting to call a Python-tool that I made, from within an add-in for ArcGIS Pro 2.9.1 using the following .NET code:
internal class LoadInfrastructureData : Button
  protected override void OnClick()
    string toolPath = "trafficanalyst.InfrastructureConnectivityTool";
    string linklayerPath = "C:\\Temp\\NaestvedDemoModelND.gdb\\TA\\Link";
    string networkDatasetPath = "C:\\Temp\\NaestvedDemoModelND.gdb\\TA\\TA_ND";
    string linkConnectivityPath = "C:\\Temp\\LinkConnectivity.csv";
    string pointCandidatesPath = "C:\\Temp\\PointCandidates.csv";
    string stopLayerPath = "C:\\Temp\\NaestvedDemoModelND.gdb\\TA\\Stop";
    string viaPointsPath = "#";
    string stopLayerWhereClause = "#";
    string linkLayerWhereClause = "#";
    string initialSearchDistance = "50";
    string maxSearchDistance = "150";
    string maxSnapDistance = "0.1";
    string[] args = {
    linklayerPath,
    networkDatasetPath,
    linkConnectivityPath,
    pointCandidatesPath,
    stopLayerPath,
    viaPointsPath,
    stopLayerWhereClause,
    linkLayerWhereClause,
    initialSearchDistance,
    maxSearchDistance,
    maxSnapDistance
    var loadInfrastructureTask = QueuedTask.Run(async () =>
        IGPResult result = await Geoprocessing.ExecuteToolAsync(toolPath, args, flags:GPExecuteToolFlags.None);
I have tried using the following as toolpath when calling Geoprocessing.ExecuteToolAsync(toolPath, args):
  • Full path to my tool - @"C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\TrafficAnalyst\esri\toolboxes\Traffic Analyst Tools.pyt\InfrastructureConnectivityTool"
  • toolboxalias.toolname – ”trafficanalyst.InfrastructureConnectivityTool”
  • toolname_toolboxalias – ” InfrastructureConnectivityTool_trafficanalyst”
  • gp.toolboxalias.toolname – ”gp.trafficanalyst.InfrastructureConnectivityTool”
Common to all four ways of specifying the toolPath parameter, is that I get the value 2147483647 as the ErrorCode from the returned IGPResult as shown below:
If I replace toolPath and args with a standard Esri tool, it works fine.
If I run my Python-tool from within ArcGIS Pro GeoProcessing, it works fine.
If I run my Python-tool via an ArcGIS Pro Python prompt, it works fine.
What am I doing wrong?
