Is there a way to find the extent of a shape file in ArcGIS Pro?
1707
08-31-2020 02:45 PM
by Anonymous User
Not applicable
This used to be so easy in ArcMap: Properties -> Source, and you could easily see the extent of the shapefile along with units. This was especially useful because it could be used to determine what sort of coordinate system you were working with.
I'm developing a lesson based around this principle, and I'm wondering if there is an easy way to see the extent of a shapefile in ArcGIS Pro.
Tags (1)
DanPatterson
MVP Esteemed Contributor
right-click, properties, a little scroll to Source, then extent
At least for shapefiles... you may want to use featureclasses in a geodatabase working with Pro
... sort of retired...
by Anonymous User
Not applicable
Dan,
I looked there and the extent tab was missing. It was then that I realized I was running version 2.4. When I updated to 2.6, the Extent Tab was there. Thank you!
