Installing python package movingpandas
7408
7
01-18-2021 01:32 PM
TimSemmelhaack
I try to install the python packages movingpandas with Arcgis Pro 2.7 It is available in the list "add packages". But I can't install it with the install button or with the conda prompt and "conda install movingpandas". Conda search movingpandas doesn't return any result.
Any ideas?
Tim
DanPatterson
MVP Esteemed Contributor
Good!
You might want to Accept as Solution the thread that answered your question @TimSemmelhaack so that it will float to the top as a solution for those that have similar questions.
... sort of retired...
DanPatterson
Did you try the install instructions from their github site?
anitagraser/movingpandas: Implementation of Trajectory classes and functions built on top of GeoPand...
the conda-forge channel might work, but I would see what this reports
conda install -c conda-forge movingpandas --dry-run
the --dry-run will give you an indication of what might be changed in your clone
TimSemmelhaack
Thanks
conda install -c conda-forge movingpandas --dry-run throws an error
InvalidSpecError: Invalid spec: =20190808
I will try it with a new clone of my standard environment
TimSemmelhaack
Even with a fresh copy of my default environment I get the same error.
Fetching package metadata ...............
Solving package specifications:
TimSemmelhaack
The cause of error could be the old conda version, which ships with Arcgis Pro https://github.com/conda/conda-build/issues/3915
DanPatterson
It is known that esri isn't using the latest version of conda, nor one that can be updated... just try updating conda.  For a little fun try
conda install -c conda-forge movingpandas --no-pin --dry-run
You could also add conda-forge to the top of the environment.yml file as well, but might see too many things wanting to be updated
TimSemmelhaack
with the parameter --no-pin and a new environment I could install movingpandas and get it to run. At the moment without errors!
Thanks !
DanPatterson
Good!
