Include more than one iterator in ModelBuilder
1330
01-22-2024 08:26 AM
RaynerCastro
Hello! I have a shapefile with multiple polygons and a folder containing several rasters. I would like to create 2 iterations to cut each raster in the folder with each polygon in the shapefile. I've been trying, but I haven't been able to achieve it. I hope one of you can help me.
DanPatterson
MVP Esteemed Contributor
Have you read the limitations Noted here?
Iterators—ArcGIS Pro | Documentation
You may have to modify your workflow
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
@RaynerCastro - this can be accomplished using a submodel approach as described here.
