links to Word Documents located on a server using a UNC path seem to work absolutely fine as Hyperlinks in ArcMap by clicking the yellow flash icon but in ArcGIS Pro 2.7.1 they are not clickable to link.
I have tried the first section at stage 5 using a fixed drive https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/use-hyperlinks-in-pop-ups.htm
i.e file:///C:\Users\temp\OperationsSchedule.docx
this seems to work fine but I cannot get something like below to work
\\ServerName\sharedDirectory\filename.doc
Is this possible?
Thanks in advance
Solved! Go to Solution.
In ArcGIS Pro, you need to configure the popup. Insert a hyperlink as a text element
I think this method is cleaner.Complete HTML as the field value. FAQ: Is it possible to add a hyperlink path to a field in ArcGIS Pro?
