How to define units of measure used for a raster layer in ArcGISPro using the standard ISO 19115-3 XML metadata style?
1974
03-31-2021 03:36 AM
Labels (2)
RehanChaudhary
i have set my metadata style to the above mentioned style in options in ArcGIS Pro before starting my project. Now i have imported multiple raster layers under my map document and each one has different units of measure and different metadata fields to be filled. When i go to the Catalog Pane for filling the metadata, i get the complete view and certain fields but its for the complete document and it does not shows any field for filling in "units of measure".
How can i assign in the metadata which units of measure have been used for a specific layer using this metadata style and hoe can i define metadata for individual layers?
Tags (3)
DanPatterson
MVP Esteemed Contributor
Is this the documentation you have been following?
Create ISO 19115 and ISO 19139 metadata—ArcGIS Pro | Documentation
... sort of retired...
RehanChaudhary
RehanChaudhary
@DanPatterson no i am using the below mentioned tutorial but if they are outdated then how can i fill up the metadata and achieve the tasks mentioned in my question. those are most important for me
DanPatterson
@RehanChaudhary in your link there is a statement
You cannot create complete ISO 19115-1 metadata in the current version of ArcGIS Pro.
If your item happens to be one of them, then you might have to wait until the ArcGIS Pro version goes forward.
