How to turn off headings from legend using python?
3478
05-19-2021 12:10 PM
WesleyCosta
Well, I'm using ArcGIS Pro 2.7 and I want to turn off the 'Headings' from Legend Item. I know how to do it manually, but I need to make a script. Thanks by attention!
JeffBarrette
Hello Wesley,
This can be accomplished using Python CIM Access:
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/python-cim-access.htm
Here is a snippet of code that does what you need.
p = arcpy.mp.ArcGISProject('current')
lyt = p.listLayouts()[0]
#Get the layout's CIM definition
lyt_cim = lyt.getDefinition('V2')
#Iterate though all layout elements to find the Legend element
for elm in lyt_cim.elements:
  if elm.name == "Legend":
    #Legend item changes
    for itm in elm.items:
      if itm.name == "GreatLakes":
        #Update visibility
          itm.showLayerName = True
          itm.showHeading = False
#Set the CIM changes back to the layout
lyt.setDefinition(lyt_cim)
There are many Python CIM Access samples located here (including legenditem changes):
https://www.arcgis.com/home/item.html?id=8772f61319584882bb697ba003030636
Jeff - arcpy.mp and Layout teams
Tags (1)
DanPatterson
MVP Esteemed Contributor
Did you look at the CIM class?  For example
LegendElement—ArcGIS Pro | Documentation
LegendItem—ArcGIS Pro | Documentation
plus others.
You didn't indicate what you had looked at.
... sort of retired...
WesleyCosta
I've ever seen the Documentation above.
DanPatterson
If it isn't on the CIM stuff, it may not be available yet.
JeffBarrette
Hello Wesley,
        #Update visibility
Tags (1)
WesleyCosta
Thanks a lot, Jeff!
