Well, I'm using ArcGIS Pro 2.7 and I want to turn off the 'Headings' from Legend Item. I know how to do it manually, but I need to make a script. Thanks by attention!
Solved! Go to Solution.
Hello Wesley,
This can be accomplished using Python CIM Access:
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/python-cim-access.htm
Here is a snippet of code that does what you need.
p = arcpy.mp.ArcGISProject('current')
lyt = p.listLayouts()[0]
#Get the layout's CIM definition
lyt_cim = lyt.getDefinition('V2')
#Iterate though all layout elements to find the Legend element
for elm in lyt_cim.elements:
if elm.name == "Legend":
#Legend item changes
for itm in elm.items:
if itm.name == "GreatLakes":
#Update visibility
itm.showLayerName = True
itm.showHeading = False
#Set the CIM changes back to the layout
lyt.setDefinition(lyt_cim)
There are many Python CIM Access samples located here (including legenditem changes):
https://www.arcgis.com/home/item.html?id=8772f61319584882bb697ba003030636
Jeff - arcpy.mp and Layout teams
Did you look at the CIM class? For example
LegendElement—ArcGIS Pro | Documentation
LegendItem—ArcGIS Pro | Documentation
plus others.
You didn't indicate what you had looked at.
I've ever seen the Documentation above.
If it isn't on the CIM stuff, it may not be available yet.
Hello Wesley,
#Update visibility
