how to select polygons in training samples manager using map view
895
01-20-2025 10:30 AM
MariaGuardado1
Hi
I have a shapefile in the training samples manager and I need to delete a bunch of polygons that I added that weren't created all at the same time (so I cannot select them in the Training Samples Manager pane without going looking for them- meaning combing through a monstrously large shapefile). Is there anyway to select the  polygons using the mapview? They all occur in a precise location.
ChelseaClifford
Hi!  I also wanted to know the answer to this question.  I don't know what I'm doing, so this is likely not the best way, but here's at least a work-around I got to work: Instead of looking at and trying to modify the training samples from the training samples manager, add them to the map as a shapefile, i.e. Add Data (not within Training Samples Manager).  Then one can select the offending polygons on the map in the ways you're probably used to (what's usual for polygons that aren't training samples), and delete.  I was worried that the shapefile might not open back up in the training samples manager properly after I did this with my issue, but it did (after I saved everything, closed the map, re-opened it, and removed the shapefile from the map).  Appears as before, less the polygons I removed.
