How to Select Parcels with Two Street Frontages
2565
10-07-2021 01:48 PM
Tex
ArcPro 2.8.3.  Apologies if this is an easy problem, but I want to identify parcels in my city that have two street frontages (corner lots, typically).  I have a ParcelPolygons layer...
... and a ParcelLines layer:
Using Select by Attributes I created a new layer consisting of ParcelLines that are StreetROW lines, but I don't know where to go from there.  How do I choose ParcelPolygons that touch/intersect with two StreetROW lines?
Thanks!
2 Solutions
DanPatterson
intersect your streets to get the intersection points,
use Near to find the parcels with a distance of zero (if the lots bound the points) or sort by distance and select those with those less than a threshold distance.
A map or a typical lot/road situation would help narrow down some possibilities
... sort of retired...
DanLee
by Esri Regular Contributor
Spatial Join tool might work - join the parcel polygons with the selected streets using the Intersect match option and join one to one. The parcel polygons with Joint_Count field value 2 in the output would be what you need.
jcarlson
You could do it in two steps, though I'm not certain it will work completely.
  1. Select StreetROW lines that touch/intersect with other StreetROW lines. This will give you ROW lines at corners/intersections, I would imagine.
  2. Select Parcel polygons that intersect with that subset of StreetROW lines.
I don't have the data to test it out, unfortunately, but see if that works for you.
- Josh Carlson
Kendall County GIS
DanPatterson
DanLee
Tex
Thanks Dan—that’s along the lines of what I was originally thinking.
