How to recreate a sequential field value using ObjectID value
6009
13
05-05-2023 07:29 AM
AndrewAidt2
I am trying to get an empty unique ID field populated. The field is CarteID. I want a prefix of SSP and use the ObjectID field. Example: ObjectID is 10234 - I want the CarteID to be SSP10234. Using Python 3, how do I use the field calculator to populate this field. What Expression do I use?
Then, going forward, is there a way to automatically populate this field when someone adds a new feature?
Thank you!
RhettZufelt
MVP Notable Contributor
That is the line number.  Not sure why yours is black (or mine is blue), probably a windows setting.
you can turn that on/off with right click (in Code Block as well).
Did you get it to work?
R_
RhettZufelt
OIC your issue now, yeah, that is a line number automatically inserted by Pro, NOT part of the code.
With line numbers off, should look more like this (with nothing in the Code Block section):
R_
AndrewAidt2
Yes! Finally got it to work. I had other issues with unregistered feature classes I had to fix first.
AndrewAidt2
RhettZufelt Thank you!
