How to recreate a sequential field value using ObjectID value
6016
13
05-05-2023 07:29 AM
AndrewAidt2
I am trying to get an empty unique ID field populated. The field is CarteID. I want a prefix of SSP and use the ObjectID field. Example: ObjectID is 10234 - I want the CarteID to be SSP10234. Using Python 3, how do I use the field calculator to populate this field. What Expression do I use?
Then, going forward, is there a way to automatically populate this field when someone adds a new feature?
Thank you!
RhettZufelt
MVP Notable Contributor
OIC your issue now, yeah, that is a line number automatically inserted by Pro, NOT part of the code.
With line numbers off, should look more like this (with nothing in the Code Block section):
R_
by Anonymous User
Not applicable
The following should work in python:
"SSP" + !OBJECTID!
As for automatically populating the field moving forward I would suggest an attribute rule.  Something like this should do the trick. The Insert Trigger ensures that the field is only calculated when a new feature is created.
AndrewAidt2
I am new to Python. How do I put this in the field calculator? What expression do I use? When I put
"SSP" + !OBJECTID!
in the Code Block I get an error: 2 parameters are missing or invalid.
Thanks!
by Anonymous User
Not applicable
Are you using arcmap or arcgis pro? Either way, when you open the attribute table right click on the field name (CarteID) click calculate field/Field Calculator and paste in the code. Make sure that the expression type/parser is python.
AndrewAidt2
I am using Pro. I pasted the code and I get the error I mentioned above.Screenshot 2023-05-05 112359.png
RhettZufelt
AndrewAidt2
RhettZufelt
Working fine in 2.9.3 and 3.1.1.
It appears as if it doesn't like the first double quote in your syntax for some reason (perhaps copy/pasted in windoze).  Try replacing or just use single quotes, they work as well.
R_
AndrewAidt2
What is the blue 1 you have at the beginning? I don't get that.
AndrewAidt2
Mine is black...
