How to publish a GP Service from Pro?
1111
07-09-2019 07:18 AM
ThomasColson
MVP Frequent Contributor
From https://community.esri.com/ideas/12258-arcgis-pro-publish-services-to-arcgis-server?messageTarget=al... I can now publish and overwrite a map/feature service. However, when I right-click on a GP service on an unfederated server, there is no "Overwrite" as there is with a feature service. Do I need to be right-clicking somewhere else? If I right-click on the GP tool results in history, I can share it with a FEDERATED GIS server, but there's no choice for any of my unfederated servers, which doesn't help me in either case as I'm needing to overwrite (update) the GP Service.
ThomasColson
ThomasColson
Coming in 2.5
ThomasColson
Publishing geoprocessing services to a standalone server is possible with Pro 2.4 as well. See https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/share-analysis/publishing-geoprocessin.... The team will look at getting this information into the broader Publishing to standalone server topic that describes the other service types."
However, can't overwrite it still, which is a problem.
DuarteCarreira
Occasional Contributor II
Didn't happen at 2.5. If you want to refresh layouts on a print service you have to recreate it...
