How to kill a notebook process
19521
18
11-19-2021 12:47 PM
ChrisCowin
I've tried everything I can think of to kill a running notebook that is stuck in a loop and nothing works. The Interrupt Kernel button is always grayed out, tried restarting the kernel through the command prompt (P Key) but this doesnt seem to do anything either. The only way I've figured out how to stop the process is to kill the entire application in task manager.
edward33
In the notebook tab in the top banner you can click "interrupt kernel". I've done this a few times with success, unless ArcPro isn't responding at all, then I find this button can be greyed out.
EugeneSosnin_GSI
You could run a command in CMD:
Taskkill /IM ArcGISPro.exe /F
It will instantly close ArcGIS PRO, with running Python too. You could save Notebook and Project when script is running, and then run the command.
HenriBrillon
I am still experiencing this instability. Can we expect Esri to introduce reliable interrupt kernel functionality soon?
chris_del101
Me too. I run a notebook and it freezes and there is no way to unfreeze. Open and closing an application is not a legitimate solution to this problem.
Interrupt kernel button is greyed out. Ending task does not work.
Kopczyknj_CDMSmith
Running 3.4.0 still a problem for me.  For those screenshotting the ribbon, here is what it looks like no matter which window you have active during the process.
Kopczyknj_CDMSmith
OK, I made a little headway troubleshooting.  For me, I was copy/pasting paths from the catalog tab over to the python window.  I noticed if I did the path copy/paste from a text file that I create before running the script and NOT the catalog window (while the script was running) I was able to maintain the Kernel interruption option.  I'm sure this has something to do with lock file management but maybe it will help others.
JeffKaplan_Boston
2025, and I am running into this issue as well. I am trying to write a notebook script that iterates through around 500 features with a searchcursor, and had to use task manager to end an accidental infinite loop.
The Interrupt Kernel button is greyed out for the whole time and the shortcut command doesn't do anything.
I am working in ArcGIS Pro 3.3, it would be great to know if this is an active bug, has been fixed in a later release, or is something Esri is looking into.
Melissa_B
2025 and running ArcGIS Pro 3.5.2 - the interrupt kernel button is still greyed out during certain operations requiring Task Manager to end the process for the whole project.  I've gotten into the habit of testing all my loops with a break at the end so I can evaluate the first result before setting it loose completely. It would still be nice to be able to stop the occasional accidental infinite loop or unexpectedly long process though.  Did come across this bug in searching for a solution though: https://support.esri.com/en-us/bug/when-using-arcgis-notebooks-in-arcgis-pro-interrupting-bug-000132...  Since the interrupt kernel button is in the ribbon, maybe the issue is related?
OscarFitzpatrick
Running 3.5.0, and still experiencing this issue in almost 2026! (Happy 4 year anniversary of this post 🙂)
