How to identify polygons that are together or polygons that include others?
1557
05-11-2021 02:21 AM
sunpit
4 Solutions
DavidPike
MVP Notable Contributor
Without more detail I can only say:
Select features by location—ArcGIS Pro | Documentation
with a spatial relationship such as Intersect and Boundary Touches etc. google the relationship option meanings for more info on the spatial relationship required.
You can also run it multiple times and narrow-down selections.
DanPatterson
For containment.... "contains" or "within" using the same featureclass for both the source or target
Select By Location graphic examples—ArcGIS Pro | Documentation
For others see the graphic examples
... sort of retired...
SteveLynch
you may also want to look at PolygonNeighbors
DanLee
by Esri Regular Contributor
You can run the Near tool with your polygons as both input features and near features. You will get two new fields, NEAR_FID and NEAR_DIST, for your polygons. The ones with NEAR_DIST 0 would be what you are looking for.
DavidPike
DanPatterson
SteveLynch
DanLee
