How to get a sum of time?
1214
03-16-2023 08:19 AM
Davec43
I'm trying to get a summary of the duration for ID's using summary statistics. Data type is text with no number format.
IDDuration
ABCD1:08:47
XYZ0:09:23
XYZ0:07:31
ABCD0:04:30
When I try to do sum of the Duration Field, I get this error:
ERROR 000315 Field Formated_Total_Duration only supports statistic types MIN, MAX, MEAN, COUNT, FIRST, LAST, UNIQUE.
Is there a work around or another tool I should be using?
KenBuja
You can use Arcade to do that. Take a look at this solution.
KenBuja
Can you convert that to a numeric time, such as minutes or seconds, and get the statistics for field instead?
Davec43
If I convert it into seconds in excel before importing the data over, it works.  Is there a way in arc to convert seconds to hh:mm:ss?
KenBuja
DuncanHornby
MVP Notable Contributor
You don't say anything about how the time is stored, as you show it, it could be as a string, so summing a string makes no sense. You need to edit your question and add more detail, especially data format and what it is you are doing.
