How to find orphan roads in network?
233
3 weeks ago
Shane_EU
New Contributor II
How to find completely orphaned roads in network?
Must not have dangles topology rule also returns roads with one not connected end.
Thanks!
jcarlson
MVP Esteemed Contributor
You could use the "Select By Location" tool to select features in the layer that intersect with other features in the same layer, then check the box to invert the selection clause.
- Josh Carlson
Kendall County GIS
Dale_Honeycutt
Occasional Contributor II
Have a look at this solution -- same problem but on a pipe network.
https://community.esri.com/t5/arcgis-pro-questions/network-topology-errors/m-p/1412516#M82125
Dale_Honeycutt
I just submitted an Idea for this: https://community.esri.com/t5/arcgis-pro-ideas/find-orphan-lines/idi-p/1499910
If you agree with this idea, give it a Kudo - I think ideas with lots of kudos get more traction with Esri.
JoseG_Esri
New Contributor II
you could use "Find Disconnected Polylines" in the Attribute Rules > Ready to use Rules
