How to create triangular grid with # points on polygon?
1611
09-02-2022 02:46 AM
MarieHartlevFrausing
Hi all,
I have a polygon that I need to create a triangular grid of 40 points on top of. The 40 points have to be as equally spaced as possible (in a triangular grid) inside the polygon. How can I create that?
I use ArcGIS Pro 2.9.0, but can update to 3.0.0 if that is better.
Thanks in advance!
- Marie
DanPatterson
MVP Esteemed Contributor
Did you see the triangle option in...
Generate Tessellation (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
